03 2.0 HDI starter problems
Has anyone had a starter failure because of a faulty ignition switch? . My ignition switch became stiff and would not return after start up,the next thing I know starter is US so replaced it.Starter was duly replaced with an aftermarket one from motor factors two days later it was toasted, a new switch comes in at £174.00 incl. vat ,my point is the starter in theory should only be getting a load when the solenoid is engaged and in that case you would hear it throwing out the pinion. HELP!
Sounds like your ignition switch has failed, they can stick in the engaged position, and the starter will be toasted in mins.
You can buy a cheap ignition switch off eBay, but you will need to transfer the immobiliser chip from you original key.
Just check the number of plugs on your old switch harness, see here for replacements
http://www.ebay.co.uk/itm/Ignition-Lock-...xySoJTPvQC
600lx or 800lx
Last Post: terryd999
Today 05:16 PM
Fuel rail pipe replacement
Last Post: Peter Palmer
Today 04:50 PM
hi all
Last Post: Andre
Today 04:07 PM
New Berlingo Auto Box - Anyone have one?
Last Post: CourierJim
Today 03:47 PM
Tyre Change...old on front new on back
Today 03:37 PM
Is anyone buying a new car AFTER April 2017?
Today 03:30 PM
Slow starter (diesel)
Last Post: zedhead
Today 03:22 PM
Are Mud Flaps the Answer ?
Last Post: berreke
Today 02:13 PM
Insurance cost
Last Post: jonny705
Today 02:12 PM
Starting issues
Last Post: brajomobil
Today 11:56 AM
