  • 16 Vote(s) - 2.75 Average
04 2.0 Hdi Engine Judder
Hi All.
I've searched the forum and found some possible answers, but the other problems seem to be slightly different.
My 04 2.0 Hdi 82K has a bit of a running problem..
The car starts when requested and idles nicely - no probs there.
Firm acceleration is smooth and rapid - no probs there .
Blasting down the road, or motorway, it's fine - no probs either.
Yet slow acceleration and gentle throttle, from Cold or Hot, nearly often than not results in a juddering of the engine. It may be a red herring but it seems worse between 1500-2000 rpm.
I've checked for air in the fuel line, cleaned the MAF and also fitted new glow-plugs as it was starting slowly.
Am I correct in thinking the EGR valve could be at fault?.Confusedcratch:
Any pointers or ideas will be appreciated.
Thanks, Martin.
Mine does same around 30mph in 4th gear if i only lightly touching, if i press the throttle on some more it stops at speed increase slightly. I have always put it down to being in wrong gear for the speed as i thing the gear ratios are set up differently on it and they have a longer range. On mine i have a gearbox/engine mount somewhere which is on its way out as well so when it does judder it is made worse by the slight knocking noise of the engine mount
[-] The following 1 user says Thank You to BerlingoHDI for this post:
  • ron
Just to add, my 2003 HDi (110k) does same. Don't think it is engine mounts. Top one got changed recently when garage changed timing belt. But still get judder. As BerlingHDi, I assumed it was too low revs.
Tbh....I cant see that being the cause.
I've noticed it happening up to 2k & I can't see Citroen making Diesels that need to be revved above that just to keep going, let alone the fuel economy harm.
My Scudo van has the same lump (+turbo) and thats happy pulling from 900.
Thanks for the suggestion though.
when i say engine mounts i not sure if it a gearbox mount, mine judders but when it does it is made worse because of the mount, it feels like a mount at bottom of engine but i not too sure as i not been underneath to look. Mine also as a slight knock on start up and when switching engine off, the judder and knock might not be connected though and i do believe it is gearbox ratios
(09-01-2013, 09:35 PM)BerlingoHDI Wrote:  Mine also as a slight knock on start up and when switching engine off, the judder and knock might not be connected though and i do believe it is gearbox ratios
My old lingo had a similar sounding knock, it turned out, after a lot of searching with the aid of a lift, to be the mount under the engine, not the gearbox. The bolts securing the metal plate part of the mount to the chassis were loose, causing the knock. It wasnt obvious to the eye the movement wasnt great but enough to make the sound travel through to the body wrk and so to the interior. After tightening the sound disappeared. Worth checkng maybe?
[-] The following 2 users say Thank You to mrbritse for this post:
  • BerlingoHDI, ron
Thanks for that, when weather is better i may check that out but at moment it aint really bothering me,
thanks again
Yes as suggested above....up on a lift and check the lower engine mounting(s).
They can come loose after time.
Surely, if I had a loose engine mount the gear lever would lurch forth and back under acceration and quick braking.?. I've got none of those problems...
I will get it on a lift shortly, just out of interest.
The movement can be minimal in that you won't notice it from the cabin, but it translates to a healthy knock when metal contacts metal.
Sop the seatbelt buckle sitting soo low?/aux ste...
Last Post: doofer
Today 09:42 AM
Head Light Bulbs
Last Post: doofer
Today 09:38 AM
» Replies: 35
Are Mud Flaps the Answer ?
Last Post: doofer
Today 09:28 AM
BerlingoForum.co.uk moving over to BerlingoForum...
Last Post: Bob Southey
Today 07:43 AM
REAR AXCEL
Last Post: ajcommercial
Yesterday 09:36 PM
Odd Issues with Rear Door Sensor
Last Post: dumdum
Yesterday 09:25 PM
display fading (MFD B, not bulb related)
Last Post: sks01773
Yesterday 07:50 PM
radio code
Last Post: Tomcat3
Yesterday 02:32 PM
Removing the rear roof storage bin (mk3 modutop)
Last Post: iscom
Yesterday 01:31 PM
» Replies: 15
New Berlingo Auto Box - Anyone have one?
Last Post: doofer
Yesterday 12:13 PM
