  • 30 Vote(s) - 2.97 Average
2000 Multispace Roof Bars
Hi there,
New to the forum. I have a 2000 Multispace (purchased last February) that came with Citroen roof bars. Can anyone tell me how to remove them? Although they appear to be original equipment (along with front bull bars) the owner's manual tells me nothing...
Photos attached.
Same with the dash clock, actually... Nothing in the owner's manual. So I'm stuck with GMT (not summer time).
Can anyone help?
Cheers,
Steve
Attached Files Thumbnail(s)
This would be a start for you:-
http://www.berlingoforum.co.uk/showthread.php?tid=109
Somebody more knowledgable will no doubt be along later and give more help
Unfortunately, those manuals only go back to 2008 or something like that; this is a 2000. And even then I don't actually see anything about fitting/removing the bars – only about maximum loading weight.
But thanks anyway...
Steve
Yup to remove them you need a special key - it's like an Allen key but 5-sided. If you don't have one then it could be tricky... if you're near York then you're welcome to borrow mine...
Shove it into the hole above 'Citroen'' and rotate anticlockwise... one side will probably be enough to release. The screw simply pulls the plastic end bits inward, which pulls hooks under the tabs on the roof.
Once you've got it off, you can replace the bolts with that weird 5-sided head for normal M6 Allen bolts - preferably stainless. Unfortunately if yours has been on a while it may well have corroded fairly solid... I broke one of the original bolts when trying to disassemble mine, which is how I know about replacing them!
Will shortly take delivery of some heavier duty AIKO bars as per this thread:
http://www.berlingoforum.co.uk/showthread.php?tid=702
As the original Citroen ones aren't all that great IMO.
[-] The following 1 user says Thank You to shedpete for this post:
  • scass
Shedpete
Thanks a lot! That's brilliant; just what I needed to know. I reckoned the hole above the Citroen mark was the key – but a no screwdriver I have worked. Now I know why!
Unfortunately, I'm in central Portugal, so York is a bit far off. And I've gotta get the bars off before taking a ferry in a week or two's time (otherwise I get into a different height band for pricing)! But I'll work it out. And the trick of replacing the screws is a good one. Very helpful!
Thanks again. Great forum for a new (secondhand!) Berlingo owner.
Steve
If all else fails just saw the bars in half :-)
Ha ha! I'll try a Citroen dealer first. If that's no good, I'll grind down a hex key to fit Smile
Steve
So it turns out the bars were pretty rusty. Managed to get one of the bolts undone with a ground-down hex key; the others were totally seized up. But some wiggling around and wrenching at the bars loosened the clamps. So all is now good – except that the bars are essentially useless.
I sourced a new pair on E-bay for £90 + postage. Citroen originals. They come with the appropriate 5-face key for installation...
Thanks for the help – gave me the confidence to attack the problem head-on!
Steve
Yesterday 10:22 PM
Yesterday 10:18 PM
Yesterday 09:23 PM
Yesterday 05:03 PM
Yesterday 12:18 PM
Last Post: Teep
Yesterday 09:12 AM
Yesterday 06:22 AM
14-04-2024 12:00 PM
Resistor cooling fan
Last Post: SteveE
14-04-2024 07:45 AM
Forum "login"
Last Post: Gryffindor
13-04-2024 05:53 PM
