I've just now fit gti6 half leathers in mine using the method suggested, does anyone else find they sit too high? I can barely reach the pedals now? Also did you remove the plastic trim off the side of the seats as mine catch the door trim?
Threads: 67
Thanks Received: 455 in 361 posts
Thanks Given: 1,045
I've put a Xantia seat in; it retained the articulation cover at the base of the backrest but all side plastic came off.
If yours feels a bit high, you could section the bases and reweld...
They definantly still need alot of work, sectioning them is an option or I may just make up my own bases yet out of box section and trim it in carpet
Thanks for the advice, think I'm going to make my own bases, seems alot easier and I can position the seat where i like. Just wish I hadnt cut up the standard seats now, I'll try get a picture once I'm sorted
Threads: 5
Thanks Received: 14 in 10 posts
Thanks Given: 14
To anyone who has fitted 306 seats in a Berlingo, do they flip forward and slide? I have a 3dr mk1 Multispace so will need to retain flip & slide function?
Threads: 8
Thanks Received: 5 in 5 posts
Thanks Given: 2
Anyone got a detailed guide? I'v just come to fit my ph3 306 thinking its be simple but nothing lining up no threaded holes on the 306 seat
Threads: 32
Thanks Given: 18
You've read the first post haven't you? The berlingo base needs drilling to suit the holes in the 306 seat, then use a nut and bolt... ... ...
