  • 18 Vote(s) - 3.11 Average
90-110 bhp differences?
What are the differences between the 90bhp & the 110bhp hdi engines, i imagine fuel pump pressure, injectors & intercooler, anything else? Or would an engine swap be easier?
This is the HDi you are asking after.
To the best of my knowledge, the 110 was never fitted in the Berlingo.
The differences are an intercooler, ECU rather than pressure operated wastegate on the turbo, therefore ECU is different and at least the actuator on the turbo itself. Pump pressure is, I think, the same and I also believe the injectors are the same.
If you are thinking of taking this route I would ask why? Depending on your answer, there may be an easier way of achieving your goal.
I've got the HDi 110 in my Berli. Turbo is different too being a twin scroll variation.
[Image: ab197646.gif]
In the UK only the XTR is available with the 110 diesel.
(According to the Cit. website.)
Not worth doing an engine swap IMO (Unless your engines knackered that is!) Adding a FMIC, de-cat with a remap to a 90 would see 150ish bhp IIRC Smile
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
yeah a remap is the way forward it would take you up to 120bhp it makes a big difference
(16-02-2012, 07:47 AM)3rensho Wrote:  I've got the HDi 110 in my Berli. Turbo is different too being a twin scroll variation.
Beg pardon - I forgot about the Mk3 only thought about the M59 when I saw the question.
If it is purely more power you are after, then, as berlingo power & PeteA say, the better route is as above. It is simpler and can be done in stages should you wish.
(16-02-2012, 06:53 PM)berlingo power Wrote:  yeah a remap is the way forward it would take you up to 120bhp it makes a big difference
This sounds good - presume torque is higher too?
Any supplier recommendations? Cheers.
2003 Multispace 2.0HDi
Yes - where are you?
Do you have Bosch or Siemens ECU?
I'm on the siemens ecu and yes torque is more important than outright bhp, im a plumber so the van gets loaded.I'm based in leicester so wheres the best and nearest place for a remap?
Tyre Change...old on front new on back
Last Post: malgpz900
Today 09:20 PM
Finally a B9 Haynes Manual
Last Post: Satellitemark
Today 08:26 PM
» Replies: 33
Fuel rail pipe replacement
Last Post: Peter Palmer
Today 08:19 PM
REAR AXCEL
Last Post: Tomcat3
Today 07:31 PM
Berlingo B9 2008 Just Testing The Water
Last Post: nickyboy4
Today 06:34 PM
Starting issues
Last Post: technique1966
Today 06:00 PM
Insurance cost
Last Post: jonny705
Today 05:33 PM
Newbie
Last Post: j.ted
Today 04:40 PM
Are Mud Flaps the Answer ?
Last Post: Top drive
Today 04:02 PM
Is anyone buying a new car AFTER April 2017?
Last Post: Solent
Today 03:35 PM
