After Using dirty diesel knock from engine what is it??
Thanks Received: 3 in 2 posts
Hey, i put in dirty diesel into my van by mistake and ever since my van has not been the same, i have 04 1.9 straight, since i put it in, the symptoms first started when my van started to heg, and spluttering trying to keep power, my engine noise went really bad as in a really bad diesel knock, van would start spluttering again and then it would sound normal, drive for a few miles then it would all happen again, i used dipetane in my fuel system, that helped the hegging and spluttering, but the diesel knock has not gone away, its a real loud knocking coming from the engine, any ideas on what would be the problem, i looked at my diesel filter that looks good as new..
any help appreciated
02-02-2014, 08:02 PM
(This post was last modified: 02-02-2014, 08:03 PM by ron.)
I would advise changing the filter anyway.Try putting some Millers in the tank.Let us know how you fare.:thumbsup: How dirty & how much did you put in?
hey, thanks for reply, would Dipetane not do the same as of Millers??, il change the filter that only a couple of euro, am was green diesel, and about 20 litres of the s**t, i have put 40 euro white diesel on top of it since the bad diesel went in
I don't know of Dipetane or green diesel.Is it the equivalent of our red? I am asking to find out why the fuel was dirty. cratch:
im from ireland if that help , dipetane is like a flush to put into the fuel system, green diesel is just used for tractors, (agri-diesel), think its like red but its green over here, the fuel was dirty because green diesel is dirty diesel and the only reason i used it as i ran out of diesel, i used some of that diesel as it was handy for my instead of going to petrol station filling up a gallon, as petrol station is about 10 or 11 miles from were i was that night.
Threads: 23
Thanks Given: 48
27
I think your problem came from when you ran out of white and pulled all the crud from the bottom of the tank through the pipes in to the filter so a new filter plus a good long bleed it can take some time to get the crud out
ok fair point. but would that make the engine to change noise from normal to like a for transit for all sakes is the way to describe it, and when its all cleared will the tranny noise go away and be back to normal again??
Threads: 23
Thanks Given: 48
27
02-02-2014, 09:10 PM
(This post was last modified: 02-02-2014, 09:11 PM by Jed Clampit.)
(02-02-2014, 08:57 PM)AdamCorbett Wrote: ok fair point. but would that make the engine to change noise from normal to like a for transit for all sakes is the way to describe it, and when its all cleared will the tranny noise go away and be back to normal again??
All i can say try it and see it should be ok
I hate to say it but I agree with Jed.:thumbsup::whistle:
Thanks Received: 2 in 2 posts
You may have ingested water so your tank needs a clean, given that. Best to change filter to reduce the amount of scum, gunk. and a fungus that grows on the inside of the tank that you can suck up. This can cause blocked injectors so explains the rough running.
If you ain't Cav you ain't
Today 07:31 PM
Today 03:52 PM
Today 09:16 AM
Yesterday 08:14 PM
Yesterday 06:49 PM
Yesterday 10:22 AM
Yesterday 06:54 AM
15-04-2024 12:18 PM
15-04-2024 06:22 AM
