Threads: 67
Thanks Given: 1,045
Most alternators have the regulator inbuilt; on many it can be changed without dismantling the entire unit. There's a choice of OEM and Chinese parts for many electrical repair items.
Threads: 67
Thanks Given: 1,045
It is much easier off the car, even when the alternator has an externally accessed regulator. Some cases you cannot replace it without removal. What brand of alternator, and is there a label on it?
Threads: 67
Thanks Given: 1,045
13-03-2013, 01:41 PM (This post was last modified: 14-03-2013, 09:05 AM by dwr400.)
Alternator removed.
But problem is how to split it?
Removed all visible bolts and nuts, except the pulley and small 4 surrounding philipses.
Dont need breaking stuff while rebuilding
while it being pain in the back to remove and install, only faulty regulator was to blame, so a quick fix.
Signs of deterioration were present, but was not aware of.
Alternator light should cut out instantly after start, not with half sec delay. Also it should charge 14.3 - 14.4V measured on battery, mine was 14V prior to fix, maybe less in last days.
Many small problems now fixed. Non perfect starting, occasional erratic idling, power delivery, even though souped to 110hp. But problems showed very subtle, now ok.
