  • 17 Vote(s) - 2.18 Average
Aux Connection To Stock Headunit Problem
Hi guys.
Work have a 2011 Berlingo, Now when i connect my ipod to the standard headunit via the aux, the audio seems to sort of skip or pause even for a milisecond as if its trying to read data.
Any idea on what this could be, I plays fine through the 3.5mm Audio Jack but when its connected via Usb the problem starts, i did think it was the data cable but its brand new so i cant see that being a problem at the moment.
Just wondered if anyone else experienced the same issue.
Ipod Used. Ipod Classic 160gb colour screen.
Thanks in advance
AV1D
You might want to have a look at the USB cable. I bought a new one to connect my Kindle to my Linux box and it was intermittent. Took it back and got a new one - problem solved.
thanks for the fast response, hmm might try it on my car head unit and see if it is the cable.
Thanks Mate Big Grin
Let us know how you get on mate.
I think its the ipod all togeather.
I have the 160GB Ipod classic, Connected it to my Sony Cdless Headunit in my car using the cable and it worked fine.
According to the Berlingo Owners manual, usb feature is only featured on the 5th Generation or above.
Anything below is to use the 3.5mm Jack port.
I dont understand how it will work and bring everything up on the console in the van and all functions work correctly with no issue at all, every so oftern the music has a sligh pause to it and it sort of jumps from 0:30 to 0:32 so maybe the Headunits arnt the best. Sad shame nice little new van to drive.
** EDIT **
Wiki states that my ipod is the 6th Generation 2nd revision, so it should be working correctly through the headunit. Im going to see if a mate has a spare cable to try. If that fails then the head unit is to blame Sad
[-] The following 1 user says Thank You to AV1D for this post:
  • Berlingo Norway
Last Post: Vossy1
Yesterday 04:37 PM
Yesterday 03:58 PM
Yesterday 12:45 PM
Yesterday 09:22 AM
Yesterday 07:32 AM
Fault Code B0079 Airbag
Timing pin sets
26-03-2024 11:50 AM
injector plastic neck broken
Last Post: magoo1
25-03-2024 05:15 PM
Multispace Forte for sale
Last Post: ffrenchie
25-03-2024 01:58 PM
Spare wheel
Last Post: chrisl
24-03-2024 09:18 PM
