Thanks Received: 6 in 4 posts
well after all my bragging about 266000 miles of motoring we have a problem the van wont start it had a couple of weird problems it went into limp mode twice this week then would not start but on second attempt went then last night went out in it fine went to go to work and it wont go at all, engine cranks fine but it wont fire, it will go on easy start but when you finish spraying it just stops again. i am thinking electrical fault of some sort but we have little info on it, I have searched the forums and found people with the same fault but no real answers any one got any ideas (1.6 hdi 57 plate)
Threads: 17
Thanks Given: 153
Maybe the Blingo has become an easystart addict coxy! Could be a vast array of problems at that mileage though. Bad times, feel for ya....
Thanks for the replies guys easy start was just to see if we could get it to go we never use it normally its a great starter normally I think it may be a sensor or ecu type fault or even imobiliser, trouble with modern diesels is to much electronics that are very difficult to diagnose gonna have to bite the bullet and pay someone to diadnose it for me I hate paying garages to do work once i know what the problem is i can fix it but dont know where to start without test equipment
Gray
Thanks Received: 7 in 7 posts
Dont despair !...go for the obvious issues first, Fuel starvation could be fuel filter needs changing or the notorious in tank fuel pump, maybe high pressure fuel pump or associated pressure regulator, how about air leak in fuel lines?...
if your stuck for ideas, get it on a diagnostic, could be just a crank or cam sensor!.....cant be terminal, as when it runs, it runs fine !!
Bet it's something simple
MPV (My own Personal Vehicle)....2.0 HDi Multispace MPV Mk2 .
I Like Cars,Women,Drink & Motorbikes but not necessarily in that order!
thanks all we are thinking crank sensor just got to plug it in and find out whats what I will let you know how we go
10-03-2011, 03:30 PM
(This post was last modified: 10-03-2011, 03:30 PM by coxy.)
Does anyone know wich manual covers the 1.6 hdi engine 07
