Brake Load Sensor!!!!
Thanks Received: 18 in 14 posts
Thanks Given: 30
The van failed it's MOT yesterday and one of the problems was the rear Brake Load sensor........ The MOT guy said that a spring on the sensor linkage has broken, therefore I have no rear brakes........ I just wondered if anybody had encountered this problem before and if so, how they rectified it?
£100 + vat for new sensor so would prefer not to go down that route. Plus the MOT guy said that it could possibly be 'Bodged' by replacing the spring. Apparently you can't just buy the spring, so just wondered how, if at all, we could overcome the problem?
Thanks fellas! :thumbsup:
Threads: 18
Thanks Given: 211
Bloody Hell! your certainly going through the wars!
Have a look at this, This is the load compensator showing the spring that's missing or broken.
The Green arrow is where the spring usually wears out, The red arrow is the pivot points what usually seize up. :thumbsup:
[Image: hvoqxv.png]
Thanks Given: 30
Yeah mate, it seems to be one thing after another at the minute. I'm just trying not to think about my corroded rear brake pipes and slantly back wheels. Getting fed up to be honest! But just going to have to tackle one problem at a time.
I've been assured that it's the spring shown in your pic that has broken. God only knows where I might get a replacement or something similar.
Thanks for the pic mate, it could prove invaluable tomorrow!
(14-09-2012, 04:36 PM)LloydyBoy Wrote: Yeah mate, it seems to be one thing after another at the minute. I'm just trying not to think about my corroded rear brake pipes and slantly back wheels. Getting fed up to be honest! But just going to have to tackle one problem at a time.
Hi,Try a garden machine shop,they are a good source of the wierd & wonderful.Measure the distance first.Good luck.
Threads: 63
Thanks Given: 410
Can't you use a fine flamed blow lamp, remove the spring, make off another eye to fit the bracket by heating and bending and re-temper the spring afterwards, may have to move the adjustment at the opposite end to compensate for length of spring.
Where have you tried, surely the proper main dealer should have the item on their parts computer and also might be worth trying your local Peugeot dealer as well....
Threads: 18
Thanks Given: 211
(14-09-2012, 07:46 PM)andy-womble Wrote: Can't you use a fine flamed blow lamp, remove the spring, make off another eye to fit the bracket by heating and bending and re-temper the spring afterwards, may have to move the adjustment at the opposite end to compensate for length of spring.
Nice one, this is what I did to the one in the picture, thats why it's stretched a bit.
Got through Mot fine.:thumbsup:
Threads: 63
Thanks Given: 410
(14-09-2012, 08:24 PM)Rustscrat Wrote: Nice one, this is what I did to the one in the picture, thats why it's stretched a bit.
You didn't used to work at the pit did you???? We used to do all sorts of makeshift repairs like that all the time....
Threads: 18
Thanks Given: 211
(14-09-2012, 08:31 PM)andy-womble Wrote: (14-09-2012, 08:24 PM)Rustscrat Wrote: Nice one, this is what I did to the one in the picture, thats why it's stretched a bit.
Machine maintenance is my bag, when you aint got the parts you have to make do with what you've got!
Thanks Given: 30
We managed to re-use the old spring in the end. But just in case anybody has this problem in the future and the spring can't be re-used this link might be useful
http://www.ebay.co.uk/itm/Peugeot-Partne...2a22a3ef93
Glad you're sorted.
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• LloydyBoy
Last Post: Bizzy9
Today 03:55 PM
Today 03:21 PM
Today 02:43 PM
» Replies: 15
Today 08:44 AM
Clutch issue?
Last Post: Paul04
Today 07:07 AM
Today 05:50 AM
Adding heated seats to a k9
Last Post: ComboLifer
Yesterday 07:24 PM
Yesterday 07:22 PM
Yesterday 07:16 PM
Rip off van servicing
Yesterday 07:14 PM
