Threads: 24
Thanks Received: 6 in 6 posts
Thanks Given: 38
its true to say that its a slow process for me to find the correct parts when the Berlingo has so many variations .
are the brake lines 5mm if i was to buy to make my own replacement lines ?
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 10
(09-07-2015, 03:22 PM)petesta Wrote: its true to say that its a slow process for me to find the correct parts when the Berlingo has so many variations .
Is it not the size of the ends which are more critical?
2001 1.9D Multispace.
Diagbox diagnostics in Northumberland.
Thanks Given: 186
44
No VIN required just go to your local motor factors and get the stuff from them ... pipes and fittings ... job done.
By the way brake pipe is measured by external diameter.
Are you familiar with pipe flaring ?
Thanks Given: 67
The brake lines are standard 3/16" pipe also called 5mm. I buy a roll of Kunifer cupro nickel pipe, you can get 25ft for about £12 and it would pipe the whole vehicle.
