Does this attach to the bottom of the stub??
Threads: 63
Thanks Given: 410
Think they may be known as a "P" bush in the trade on account of the shape, sorry but I don't know the actual techie description
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Rear wishbone bush looks like
Thanks Given: 4
Does looke like wishbone mounts in my previous experiences it easier swapping them with poly bushes some fine it easier replacing the whole wishbone as the bushes are a pig to remove!
Threads: 36
Thanks Received: 87 in 84 posts
To remove the bush once the wishbone is off the car destroy the rubber part (you could use a blowlamp) and then use an angle grinder on the metal sleeve until it starts to split (be careful not to go right through and mark the pin). Press a new one on making sure that you have the alignment right. (My press was a lump hammer)
Peter
Many thanks everyone. Replacing the wishbone today.
Threads: 63
Thanks Given: 410
(27-12-2011, 12:35 PM)Neds Wrote: Does looke like wishbone mounts in my previous experiences it easier swapping them with poly bushes some fine it easier replacing the whole wishbone as the bushes are a pig to remove!
Can you please tell us where to obtain the polybushes from???
