Citorn berlingo 99 1.9d - Electronic problem
Hi,
My car is berlingo 1999 1.9d WJZ.
M49 body chassis.
VIN VF7MFWJZFXG003133.
The issue is with the the electronics.
1) no rear left tail light .
2) no front right park light.
3) no air conditioning blower.
4) no tear licance plate lights.
5) Air bag light came on - open circuit.
The bulbt seems ok and i tryed with test light to see if there electricity coming
and no electronic .
Also tested with multimeter and get the same.
Please help me with:
- I don't have fuese box diagram to troobleshot it.
- Is there a relay that resposible for that issue ?
Confused
Sounds like fuse
(08-06-2016, 04:39 PM)Johny555 Wrote:  Sounds like fuse
Yes.
I found the fues 19 has no electricity at all.
and fuel 9 has power in only one side.
Put a new fuse in and see what's working
(08-06-2016, 09:46 PM)Johny555 Wrote:  Put a new fuse in and see what's working
I have change the fues.
sorry i didn't taled that i removed the fues and power test the circuit and it still the same.
So its a problem before the fues.
Do you know where should i look ?
All I can think is start looking at the wires before the fuse box,,strange?.
The more likely suspect is the BSI box installed under the fuse block near the drver's left knee. It has 3 fuses on it. The clue is the ventilators and/or air conditioning dead.
Only problem: it's a bitch to get it out. The damned thing controls a lot of things in the car and has inside about five relays too.
(09-06-2016, 06:06 AM)Saandy Wrote:  The more likely suspect is the BSI box installed under the fuse block near the drver's left knee. It has 3 fuses on it. The clue is the ventilators and/or air conditioning dead.
Thank
I have more information about my issue
Quote:Fuese 9 and 18 has problem in circuit.
FUSE 9 - Tail light(s) , Number Plate lights(s), 5.0A
FUSE 18 - rear fog lights , indicator light , 5.0A
Also diagnose and found that in the passenger compartment fuse box,up yo RPO No . 8599
Fuse number 18 and 9 have issue, but it is not with the fuse.
Issue with fuse 9 :
- only power at one side of the fuse.
- Removed the fuse at test the circuit it with test light and i have the same result.
Issue with fuse 18:
- Tested the fuse with test light ,when its in the circuit and it has no power at all.
If there only power to one side of the fuse,surly the fuse has blown??.maybe its time to go to auto eclectrition,,, and rear fogs only 5amp fuse?? Seems to low for foglights.
I did a continuity test with multi-meter ... and it worked.
Its the best to just change the fuse and see what happend
Today 09:06 AM
Today 09:03 AM
