My clutch in my year 2000 1.9d Berlingo is sitting high the biting point is perfect it goes into gear perfect i just don't know if it's my clutch or my cable or what could it be?
But it's not an adjustable cable?...could the cable stretch over time letting the clutch sit higher?
Could it be the release bearing?
No,it won't affect the pedal height.
Threads: 40
Thanks Received: 389 in 346 posts
Thanks Given: 127
28
On the 96 models and later ones , the clutch cable has an automatic adjuster halfway on its length and sits behind the crossmember behind the sump. This is set when the cable is installed .
