It's been a while since my last post or login to the forum, so hello to all again.
Having an issue with the door central locking, lock then immediately unlocks and display saying door open, courtesy lights on, my question is:-
Can someone direct me to the wiring/circuit diagram for the central locking (no deadlocks) and internal door switch wiring colours/no's I've got a Haynes, however, it doesn't show the courtesy light switch wiring, I can trace the wiring but wanted to have something to hand prior to stripping things down and tracing (My suspicion is o/s/f as it's the most used), I've checked continuity of wiring at door hinges and all check out fine even when wiggling wires so know I've an issue at door/lock side of one of the doors, even if someone can give me the pin no id's on the lock modules for the internal switch, I can take it from there, Many thanks in advance guys.
