Threads: 11
25-03-2013, 06:35 PM
(This post was last modified: 25-03-2013, 06:36 PM by Kirkham2010.)
hi all :lol:
Got a slight problem with the electric window on the passengers side,
It stopped working about 2 weeks ago, The drivers side still works fine so I'm guessing its not the fuse?
When I press the window button there's no clicking from the relay?
any ideas would be really helpful ......
Its a 56 reg 1.9D
Cheers :thumbsup:
Threads: 50
Thanks Given: 744
I don't think the motor is operated through a relay. Have you checked fuse 12 on the BSI fuseboard?
Door card off and provide the motor with 12v. If it fails to run you need to inspect the motor,
could be worn brushes.
Threads: 11
BSI fuseboard? is that the one under the steering or bonnet?
I hit the CTRL key but I'm still not in control!:thumbsup:
Threads: 50
Thanks Given: 744
That's the one beneath the steering wheel. There two rows of fuses
No.12 (Coloured green and 30Amp) is the third from the left on the back row, according to my owners manual.
(Which of course could well be wrong!!)
Threads: 11
Hi mate, right checked the fuse and thats fine, also swapped the buttons over and its not the switches, gonna take the door panel off 2moro and have a look at the wireing and motor.
Threads: 50
Thanks Given: 744
Do us all a favour and PLEASE change your avatar....Thanks!
