Please can anyone tell me if any 2003 - 2008 front hub with abs will fit a 2005 2.0hdi multispace desire?
Cheers
Rechid
Threads: 67
Thanks Given: 1,045
I think provided it's not 4WD or "increased ground clearance" or non-PAS, you ought be fine.
The following 1 user says Thank You to addo for this post:1 user says Thank You to addo for this post
• Rechid
I've discovered that a picasso hub is the same!
Thanks Given: 67
(20-04-2013, 10:55 PM)ron Wrote: (20-04-2013, 07:44 AM)Rechid Wrote: I've discovered that a picasso hub is the same!
That paints a completely different picture.cratch:cratch:
I wouldn't fit a Picasso hub, the wheel studs will be where the caliper should fit and all stupid stuff like that. :whistle:
