Thanks Received: 2 in 1 posts
13-01-2012, 02:49 PM
(This post was last modified: 13-01-2012, 03:39 PM by Erwanix.)
Hello, I have to change a bulb in the heater dashboard.
Should I take off all the 3 covers of the dashboard and the radio to access to this damned bulb?
It was much more easy changing the bulb of the central display!:woop:
Yup, this is a problem I've also got.
Anyone any suggestions?
Threads: 17
Thanks Given: 153
(13-01-2012, 02:49 PM)Erwanix Wrote: Hello, I have to change a bulb in the heater dashboard.
The simple answer is yes..
There are hidden screws at the top under the multifunction display, above the audio unit and the heater control knobs have clips top and bottom.
You only have to lift the top unit to access the screws, and may not have to remove radio depending on surround etc...
