  • 29 Vote(s) - 2.79 Average
Rear screen wash !!
#11
Thanks guys for the input had a wee poke about today jet is on the rear wiper Smile motors all seem to be going still no water to the rear emptied the resevior filled back up O-ring on filler neck was shot so replaced that refilled, water comming from the bottom of the header tank so hoping there is a pipe off that end next job how to get to the pipes ??
Any ideas do i need strip all the plastic from around it or can i get it from underneath? And a big thanks for the help so far :thumbsup:
you access it from the drivers wheel well, remove the wheel and then the inner wheel liner.
[-] The following 1 user says Thank You to steve valentine for this post:
  • blingo driver
CHEERS STEVE WAS HOPING I COULD GET TO IT FROM BELOW THE CAR WITHOUT HAVING TO STRIP EVERYTHING AROUND IT :justno: WILL PUT IT ON THE TO DO LIST FOR NOW :thumbsup:
(10-11-2011, 06:05 PM)blingo driver Wrote:  CHEERS STEVE WAS HOPING I COULD GET TO IT FROM BELOW THE CAR WITHOUT HAVING TO STRIP EVERYTHING AROUND IT :justno: WILL PUT IT ON THE TO DO LIST FOR NOW :thumbsup:
Sorry to dissapoint, if it were that easy it would be a Vauxhall. (Reach for the carbolic and wash my foul-mouth out)Confusedillyme:Confusedillyme::whistle::whistle::whistle:
WELL AT LEAST I HAVE SPACE IN THE BACK FOR A BUCKET AND SPONGE WHEN IT NEEDS A WASH Wink WITH ALL THE RAIN WE GET HERE IN SCOTLAND WHO NEEDS A REAR WASHER LMAO Confusedillyme:
If the wash motor turns out to be knaffed you can buy one off ebay for £6.50 including delivery. I just changed mine due to it blowing fuse when rear screen wash operated.
Remove offside drive wheel then remove two screws located underneath which secure liner at front.You can then bend & pull liner out to access motor.If its a cold day pour some hot water on liner & it will make it more pliable same applies to the tubes.
2003 Citroën Berlingo 2.0HDi Multispace Desire
[-] The following 2 users say Thank You to BlueBlingo for this post:
  • blingo driver, ron
will have a go at it next dry day until then i will live with it thinking it must be the hose that has came off Rolleyes front washer works fine and when i fill the header tank water from bottom of car so heres hoping Confusedunny:
ebay link for wash motor : http://www.ebay.co.uk/itm/230638097089?s...1497.l2649
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • blingo driver
