Threads: 147
Thanks Received: 387 in 254 posts
Thanks Given: 263
11
Looks good, not all taxis are this neat.
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• taxi
Thanks Received: 3 in 1 posts
I've got something similar in my MK1, they're wired up to the door switch so come on when the door's open.
(got some nice blue ones wired up to a straight forward on/off switch as well)
Threads: 0
Thanks Received: 3 in 3 posts
Which lights did you buy -> install exactly?!
09-11-2011, 08:42 PM
(This post was last modified: 10-11-2011, 09:53 PM by pug.outdoor.)
Used the Dioder from Ikea, cheap and 4 strips for 40€
Don't buy the color leds or cheaper set.
1 on each sliding door, 3 on back door.
Works very well on 9 volt battery in my rooftent 4 Dioders will
stay 4 hours on 1 Bat
Just perfect
Ph!l
Thanks Received: 57 in 41 posts
Thanks Given: 33
I have now fitted white led strips to the inside of the net holders above the rear doors.
I fiited them to the inside so they are like uplighters,and as I never use the nets it's no problem.Fitting them underneath would have made them visible and given too much glare.But there is plenty of light to see,even on the floor.
I wired them into the rear interior light so they come on when either the rear doors or tailgate is opened as well as when unlocking the car with the remote.
The following 1 user says Thank You to XTR for this post:1 user says Thank You to XTR for this post
• taxi
