  • 19 Vote(s) - 2.63 Average
Is this the fuel pump?
Just trying to find out if I'm lucky enough to run on rapeseed oil!
It says Pierburg which sounds familiar but I thought Bosch or Lucas were the likely manufacturers of Berlingo fuel pumps...
[Image: IMG_0119.jpg]
Correct me if I am wrong but is that not the vacuum pump for the braking system you have photographed there???
Doh! Thanks andy. It's to the right of the cylinder head as you look into the engine bay from the front, by the fuel filter so I took a guess while I had the bonnet open to check oil.
Diesel fuel injection pump is located at opposite side of the engine (LHS) and slightly below cylinder head level.
Follow the metal pipes back from the injectors and thes lead to the pump. Usually a small tag or label on pump with manufacturers name etc and usually Siemens or Bosch..
[-] The following 1 user says Thank You to andy-womble for this post:
  • chronyx
Many thanks Mr womble Big Grin
