Threads: 12
Thanks Given: 12
I have just bought some second hand Peugeot 206 wheels with excellent 175/65/14 tyres on for my berlingo but the back ones are rubbing when going over bumps and cornering. My previous wheels were 15 inch Peugeot wheels with 195/65/15 tyres on but they were not rubbing. Any ideas what could be the reason for the rubbing as i'm totally confused?
Threads: 50
Thanks Given: 743
As Jed sed (!) The offset on the 206 is different to the Berlingo which is 108.
Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
I have 205 1.6 GTI wheels on my Berlingo and there is no rubbing with the Italian wheels but the French wheels rub everywhere..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 68
Thanks Given: 22
Check this out...
http://www.wheel-size.com/
There is a good resource if you Google wheel PCD or fitments..
Threads: 68
Thanks Given: 22
Threads: 12
Thanks Given: 12
Im just wondering if 5 mm spacers would be enough.
Threads: 68
Thanks Given: 22
Threads: 12
Thanks Given: 12
10-04-2015, 10:04 PM
(This post was last modified: 10-04-2015, 10:08 PM by tmm.)
Thanks for the link ajcommercial.
Using the link provided the
Make year pcd offset bore
Berlingo 96 on 4×108 15 to 18 65.1
206 98 on 4×108 20 to 25 65.1
So If the offsets are worked out in mm? then a 5mm spacer would solve my problem?
