Radiator removal
Hi,
I need to replace the radiator on my 2006 Berlingo 1.4 petrol.
I've read many of the very useful threads but still have a couple of questions.
I can see that I need to release the 3 main hoses by squeezing the metal clips with a pair of grips. Also to remove the smaller feed from the expansion tank.
But still not sure how to then release the radiator from the cone shaped rubber mounts at the top of the radiator. I see there is an 8mm nut/screw tucked away which is almost impossible to get at, but have read that the rubber mount/clips lift up somehow. Is that correct? I am reluctant to push/pull these too hard with a screwdriver in case they snap.
Also, if I manage to get the old radiator out, how many bleed locations are there on a 1.4 petrol Berlingo? I have found one 'tyre valve' which I believe is a bleed screw, but can't see any other (I have read there may be up to 3 of these), either on the radiator or under the bonnet.
Many thanks.
Last Post: Bizzy9
Today 03:55 PM
Today 03:21 PM
Today 02:43 PM
» Replies: 15
Today 08:44 AM
Clutch issue?
Last Post: Paul04
Today 07:07 AM
Today 05:50 AM
Adding heated seats to a k9
Last Post: ComboLifer
Yesterday 07:24 PM
Yesterday 07:22 PM
Yesterday 07:16 PM
Rip off van servicing
Yesterday 07:14 PM
