Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Hi, getting a intermittent rattle from rear door / rear window area- cannot seem to locate exact spot. Anyone suffered from this ? If so, how best to fix it ? Thanks.
Former 2011 Mk3 XTR owner
alut:
Threads: 11
Thanks Received: 2 in 2 posts
Thanks Given: 27
Have you checked the lock sometimes comes loose and gives a rattle;0)
Threads: 13
Thanks Received: 57 in 48 posts
As blingo said. Check the locks. My boot lock plate bolts loosened and the boot used to rattle over bumps etc.
Sent from my GT-I9000 using Tapatalk 2
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 96
Thanks Given: 709
It now seems more likely to be coming from the top rear corner ( passenger side ) possibly eminating from behind the aperture which the central seat belt appears out of.
alut:
Threads: 13
Thanks Received: 43 in 34 posts
Thanks Given: 11
We had a rattle early on - it was the catch on the sliding door window, the nut wasn't quite tight enough.
The Bus II: 2019 XL Flair 1.2
The following 1 user says Thank You to Guanajuato for this post:1 user says Thank You to Guanajuato for this post
• taxi
