  • 6 Vote(s) - 3 Average
Right parts BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
Hi there
I just got my part to change the timing belt on my Berlingo (MF) 1.4 i (MFKFX, MFKFW). (edit: 2005 model multispace)
The parts i got was timing belt TB-5575XS GATES
And waterpump driven by timing belt
WP-511 VALEO
Can anyone confirm that this is the right part for my car?
Not sure of the engine number.
Where i can find it?
My Car INFO:
CITROËN BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
2005 Mod
Volum: 1360 KW: 55 HK: 75 Fuel: Gasoline
Which year is the engine from?
Some time during 2002 they introduced an automatic tensioner, and the belt and pump also changed then.
the older belt has 108 teeth, the new one has 104,
The pre-2002 pump has 20 teeth, the post-2002 has 18 teeth.
If you have the older motor, the Haynes manual suggest making an 8 x 8 mm square tool for tightening up the tensioner. This is a waste of time as that's the same size as the sump plug, so a proper plug kit for 3/8" socket would do the job with less fuss.
[-] The following 1 user says Thank You to Gadgetman for this post:
  • Varg
(23-04-2013, 03:56 PM)Gadgetman Wrote:  Which year is the engine from?
Ops sorry my bad. Totally forget the year Smile
The year are 2005
I will change the waterpump and the tensioneralso
New pump i got has 18! Thanks! And yup, got the right 104 tension belt. Thanks!
My Car INFO:
2005 Mod
Today 06:49 PM
Today 10:22 AM
Today 06:54 AM
Yesterday 10:18 PM
Yesterday 12:18 PM
Last Post: Teep
Yesterday 09:12 AM
Yesterday 06:22 AM
14-04-2024 12:00 PM
Resistor cooling fan
Last Post: SteveE
14-04-2024 07:45 AM
Forum "login"
Last Post: Gryffindor
13-04-2024 05:53 PM
