Threads: 7
Thanks Given: 5
Howdo.
Couldn't believe it when a friendly copper helpfully pointed out today that both my brake bulbs had gone, I only had them changed late last year!
Is it just bad luck or likely a symptom of some underlying problem?
Would I be better considering longer lasting LED replacements, are they legal, if so can anyone recommend any from Amazon?
Thanks Given: 316
15
Start simple check your fuses first - replace blown bulbs with a good quality brand of standard bulb - then take it from there.
The following 1 user says Thank You to polar for this post:1 user says Thank You to polar for this post
• Metal Mickey
Threads: 7
Thanks Given: 5
Thanks. Is there any point spending a little more on LED in the hope of longer life?
Thanks Given: 316
15
LED lamps can cause problems and generally not worth the hastle on things like stop lights IMO.
I do believe some of the lads have fitted LED's with varying results but a decent standard lamp should last between 20-40k depending on use.
• Metal Mickey
