  • 16 Vote(s) - 2.81 Average
2005 1.9d Won't start (electical problem?)
Hi,
Can anyone help me with my dead berlingo?
It turns over but does not start.
The side lights come on with the ignition.
The clock/radio/eco mode display is dimmer than usual.
Radio / Horn / Lights / remote locking don't work. (but central locking still does).
I've followed the BSI reset procedure - no luck.
I've removed the BSI to check for water damage. It appears to be fine.
thanks,
James.
Haven't been playing with the key and lost the transponder have you?
Nope, I think the key is fine.
I think I would first have the BSI checked and maybe re-set. BlueBlingo lives in Donny and he has a Lexia so PM him to see if he can help you out.
[-] The following 1 user says Thank You to Ol'Jeffers for this post:
  • spasmj
Lexia will not show us whether is a fuel in a fuel pipes or not. Main check is to connect electrovalve in HPFP directly to battery and try to start engine. So we'll bypass immo.
[-] The following 1 user says Thank You to pk7478 for this post:
  • spasmj
Thanks for the replies, I will take a look at the fuel pump (once i've found out where it is.)
