Todays problem...Wont start.
The dashboard lights up, pre-heat and everything works, battery is good.
I try to start the engine and nothing happens, no sound, no clicks, nothing.
I tried bridging the starter solenoid but nothing, except a few sparks.
Has anyone any idea's or have I found the problem already? (The solenoid?)
For the second time this week, the van is stuck on the drive.....
Arse.
Sounds like starter motor.
Old school trick. Tap the starter with a hammer while someone tries to start it
Safety warning. Don't leave it in gear or you might die
[-] The following 1 user says Thank You to Yorki for this post:
  • whitebus
Agreed, does sound like starter, but make sure battery is charged fully. A flat battery is similar
(01-05-2016, 10:46 AM)Yorki Wrote:  Old school trick. Tap the starter with a hammer while someone tries to start it
Tried tapping the starter, arcing the solenoid etc.
Nothing, except the tick of the fuel pump.
Is the concensus that my starter motor is knackered?
Have you tried to bump start it
(01-05-2016, 11:44 AM)Yorki Wrote:  Have you tried to bump start it
Havent tried that yet.
Its a diesel and Im not the fittest...
Get a neighbour to push. Give heater plugs a couple of warms first and then bump it. Should fire up
Sent from my SM-G900F using Tapatalk
I'd go for a starter. As said above a push start will tell you Smile
You could tow start it!
Last Post: Vossy1
Yesterday 04:37 PM
Yesterday 03:58 PM
Yesterday 12:45 PM
Yesterday 09:22 AM
Yesterday 07:32 AM
Fault Code B0079 Airbag
Timing pin sets
26-03-2024 11:50 AM
injector plastic neck broken
Last Post: magoo1
25-03-2024 05:15 PM
Multispace Forte for sale
Last Post: ffrenchie
25-03-2024 01:58 PM
Spare wheel
Last Post: chrisl
24-03-2024 09:18 PM
