Threads: 6
Hi All,
I have fitted a new front coil spring but my manual has not arrived yet. Can anyone supply the torque settings for:
Drive shaft nut
Steering ball joint
Anti roll bar joint
Brake caliper bolts
Many thanks
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
Hi Green Monster
1. 320nm
2. 35nm
3. 40nm
4.27 nm
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Threads: 6
Many thanks. 320Nm seems high, this explains why I needed to use a long extension on my socket set to undo it. Should have the MOT passed tomorrow.
Threads: 17
Thanks Given: 6
Hi GM,
Re drive shaft nut. I assume you mean the large nut under the lockingcap secured with "R" clip. If so that's the correct setting according to the Haynes manual.
Griff
Landmark
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Good luck getting it to 320nm
