Thanks Received: 10 in 9 posts
Thanks Given: 40
I have just changed drivers side brake cylinder and bled brakes....the handbrake works real good and the brakes feel firm, the pedal doesn't move when my foot is hard down on it...but the stop warning light is on and the brake warning light too... I checked level of brake fluid n topped up as I bled...
Does anyone e have any ideas????
The van is a 2006. 1.9D. Non turbo Berlingo
Thanks in advance!
Sooty
French Electrics......Grrrrrrr!
Thanks Received: 22 in 19 posts
Thanks Given: 17
There might be nothing wrong, they are known for being very sensitive, I found that hilly or windy twisty roads made mine go off but it stopped after I topped it up... is the light constantly on? mine usually went off a few miles down the road...
Thanks Given: 40
Yes. I drove about ten miles after I read your post. Job done. Thanks for the reply. I thought I had buggered something up!
Sent from my MotoE2(4G-LTE) using Tapatalk
Threads: 21
Thanks Received: 24 in 21 posts
Thanks Given: 133
mine used to drive me nuts,if it came on I had to stop,even though you know there's nothing wrong,i ended dripping fluid in to nearly the top of the filter,mine also came on after a spell on yorkshire dale roads etc,been ok for over a year....touch wood :-)
Thanks Given: 17
Aye mine is filled well past the max also...
Sent from my HTC One_M8 using Tapatalk
