Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
22-09-2016, 04:10 PM
(This post was last modified: 22-09-2016, 04:11 PM by Landmark.)
Hi,
Ours was a petrol model, so location of sensor may be different. If one fan is not turning I'd recon it's seized.
Griff
Landmark
Ex 1.4 Berlingo Multispace
Threads: 17
Thanks Given: 6
Hi, Just dug my old Haynes manual out
Cooling fan switch without air con -blue wire connection and located in left hand side of radiator.
With air con -fans controlled by air con system control unit and temp sensor located in thermostat housing- brown wire connector.
HTH,
Griff
Landmark
The following 1 user says Thank You to Landmark for this post:1 user says Thank You to Landmark for this post
• kevin58
Threads: 7
rate I had a look and cos I got air con fitted as well I think it's beyond me not messing with so off to garage again for fans to be sorted so am selling one of my organs now lol
Threads: 17
Thanks Given: 6
Hi Kevin,
Have you sorted the problem yet?
Griff
Landmark
Not sure if this is relevant to this thread but I had a fairly long standing overheating issue in my Petrol 1.6L The problem was solved when I couldn't get it started one morning and the garage fitted a new Coil Pack. I suspect that the old one may have been faulty for some time.
