Threads: 6
hi guys, where can i find the horn in a mk2 berlingo, had a look but cant see anuthing, is it under wheel arch ?
Threads: 40
Thanks Received: 390 in 347 posts
Thanks Given: 127
28
Behind the front bumper . n/side under the inner wing plastic cover.
They have been well hidden
Thanks Received: 3 in 3 posts
You need to take the front bumper off
The horn is located at the passengers side.
Unscrew the front faceplate then the 3 screws at the top of the bumper and more screws/bolts at the bottom of the bumper. You will then see the horn once the bumper is partly removed from the van. The only tricky part i found getting the bumper off was that it is clipped in at the wheel arch. A cloth wrapped round a straight head screw driver will release it though.
Threads: 6
Cheers guys, just as I thought........hey Hols....off with the bumper it is....lol
Threads: 19
Thanks Received: 51 in 49 posts
Thanks Given: 17
You can disconnect the horn without removing the bumper.
Do this, lengthen the wiring an fit your new horn with the slam panel securing bolt at the top next to the battery. I've done this... much less buggering about.
Sent from my SM-N9005 using Tapatalk
