i have Mk3 multispace 58 plate , the drivers side electric window has stopped working , its not the fuse as the passenger side works ok any advice on what could be the problem Much appreciated ;-)
Threads: 50
Thanks Given: 744
The driver's side may be separately fused. Apart from that it could be the switch (easy to check), the wirng
or the motor. ( maybe brushes.)
Ok it's the switch that's faulty, managed to get the centre console apart , the switch is a valeo pt number 9662428277 .. Anybody recommend best place to buy then , or do I just go to the Citroen dealer ?
Threads: 50
Thanks Given: 744
Probably the main stealer is the only place to go. If you show the average storeman a Valeo part
he'll most likely give you a blank look....Flatter him! Tell him you
need the switch for the driver's side window.....He can then quote the Citroen Part No.
and be able to tell you how many months you'll have to wait to get one!! LoL!
Thanks Received: 8 in 7 posts
I got quoted 35 quid at the main stealers (robbing b*stards!) so I didn't bother replacing. The electrical part of the switch is ok just the top rocker plastic pivot bit is a bit dodgy.
Rich
