  • 24 Vote(s) - 3.63 Average
hand brake warning light.
Hi Guys, I've got an X reg 1.9 D multispace with 67,000 on the clock, it's a great car but it's developed a very annoying fault. When driving along the hand brake light comes on and the warning beeps, it doesn't do it all the time just now and again and it goes out on it's own. Has anybody got any idea what could be causing it.
Cheers
Doc..
handbrake switch faulty?
Cheers Steve, I had got it into my mind that it would be a lot more complicated than that, I suppose thats what you get for driving a Mercedes for the last 6 years, everything on Mercs is so complicated.
Doc..
Could be low brake fluid level.
2003 Citroën Berlingo 2.0HDi Multispace Desire
Thanks BlueBlingo, I've just found out from the owners manual that the handbrake warning light doubles as a brake fluid level warning light, I'll check the level when it's light tomorrow.
Doc.
Low brake fluid could either be a leak, worn discs and or pads or rear shoes / drums worn
Follow this link which is in the how to section
http://www.berlingoforum.co.uk/showthread.php?tid=1262
Within it You will find loads of info for checking brake components for wear.
Panic over, the fluid level was a bit low. I checked the brakes over and all seem quite new and can't find any leaks, topped up the fluid and all is fine.
Doc..
Keep a close eye on it. With yours being a diesel, it is possible that it could be leaking into the servo via the master cylinder seal very slightly, if all else is, as you say, ok.
Users browsing this thread: 2 Guest(s)
What to look for when buying?
Last Post: aneng
Today 03:54 PM
clunking noise
Last Post: my mucker
Today 03:39 PM
brake warning light
Today 03:05 PM
Not a Berlingo but very intresting
Last Post: Mrleadfoot
Today 02:43 PM
Boot box dimensions?
Today 02:29 PM
Help needed have immobiliser fault and fan probl...
Last Post: Dennyboy
Today 10:21 AM
After market cruise control
Last Post: cancunia
Today 10:13 AM
TRAILER WANTED
Last Post: ffrenchie
Today 09:28 AM
touchscreen firmware version
Last Post: manelux
Today 08:46 AM
Newbie
Last Post: Andre
Today 08:29 AM
