Thanks Given: 188
23
To get the airbag off turn off the ignition and wait ten minutes until the BSI has shut down. Remove the steering column shroud to get better access. If you then feel and look at the back of the steering wheel you will see 3 holes. You need a small flat blade screw driver to go in the hole and you will feel a spring, gently lever the spring while pulling up that part of the airbag. Move on to the next spring until the airbag comes away but be careful not to strain the ribbon cable to it. Now you have access to the earth connection. Its not as difficult as it sounds just take your time and don't force anything. If you have an Haynes manual there are photos in there to help.
Are we there yet?????
Thanks Received: 31 in 27 posts
05-10-2015, 08:49 PM
(This post was last modified: 05-10-2015, 08:51 PM by JohnM.)
If you have weird stuff happening with the electrics re-set the BSI unit, that often sorts things out, Fixed my horn when it stopped working. There should be lots of posts on here to explain how to do it. It is unlikely to be the horn button if it works when the engine is off.
Thanks Given: 188
23
Ive done this mod on both my berlingos when the horn didn't work even when the engine is off and its worked perfectly ever since.
Thanks Given: 188
23
Yes you can do that to be on the safe side.
Thanks Given: 186
44
Just follow the advice ...
If the horn works with the engine off how can it be the horn push? I know bad earths can cause some strange faults, but the horn working under some circumstances does tend to suggest the horn push works. You have to re-set the BSI if the battery has been disconnected so why don't you try that first?
