Threads: 16
Thanks Received: 4 in 2 posts
Thanks Given: 11
04-03-2013, 11:51 PM
(This post was last modified: 04-03-2013, 11:52 PM by wiggers.)
hi guys, i have a 2.0hdi with a leaking rocker cover gasket. to change the gasket u need to remove the timing belt cover. But im struggling to get to the cover lowest bolt.
is there an easy way to reach this bolt to remove the cover?
cheers Chris.
Threads: 67
Thanks Given: 1,045
05-03-2013, 10:00 AM
(This post was last modified: 05-03-2013, 10:01 AM by addo.)
Hi Chris, not sure about an "easy" way but generally if a timing area bolt is being difficult to reach one approach is to put a jack under the sump, and remove the offside top engine mount. Then you raise or lower the motor gently until the bolt or nut is accessible.
Remain wary of the fact your motor is on a jack; don't get under it or place you hand where it may be squashed if the jack slips away.
The following 1 user says Thank You to addo for this post:1 user says Thank You to addo for this post
• wiggers
Threads: 16
Thanks Given: 11
thanks guys. reached it by removing offside wheel. cheers for your help
