Starting problem - Printable Version +- Berlingo Forum (https://www.berlingoforum.com) +-- Forum: Specific Model Chat, Problems and Faults (https://www.berlingoforum.com/forum-8.html) +--- Forum: M59 Berlingo (https://www.berlingoforum.com/forum-28.html) +--- Thread: Starting problem (/thread-9505.html) |
Starting problem - ytre - 18-04-2014 My diesel berlingo van is very slow turning over and wipers jump a inch at a time up the windscreen when its turning over, battery is showing 100% charge, the clock hands jump up and back again. Can anyone point me in the right direction. Thanks RE: Starting problem - ron - 18-04-2014 If you're CERTAIN the batt is ok,check all earth connections first then live as well.Good luck.:thumbsup: RE: Starting problem - Jed Clampit - 18-04-2014 If the battery is ok i think it's your starting motor RE: Starting problem - ytre - 21-04-2014 Thanks Ron and Jed, it was the battery after all. 2 cells knackered. Many thanks RE: Starting problem - ron - 24-04-2014 A good result.A battery is easier to replace.I hope you fitted a good one.:thumbsup:alut: RE: Starting problem - Jed Clampit - 24-04-2014 Glad you got it sorted the give away was when turning over the wipers jumping good sign of a flat or dying battery |
