Threads: 24
Thanks Received: 80 in 59 posts
Thanks Given: 6
I mean seriously... They appear to be made out of Ryvita.
Thanks Given: 44
You can get a set of plastic trim removal tools from ebay for not much cost.
Thanks Given: 67
Is that special string or can we just use any brajo ? I like the
push pin fittings where you plip the dot in the middle and they just pull out then you pull it out and push the dot in level to fasten it again. They should all use those and save us all a lot of trouble
Thanks Given: 184
44
[quote They should all use those and save us all a lot of trouble
[/quote]
Trouble is there are so many fuckwits out there that wouldn't know how to undo them and they would then end up on here complaining about them being rubbish !
• andy-womble
Threads: 24
Thanks Given: 6
I'll try that tip, thanks.
The trouble with these we're that they were the ones on the tailgate trim where you can't access the clip easily from the outside...
