Hi all I'm after a Bsi unit number 9657999680 Berlingo 03 reg 1.9 non turbo.thanks
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
if you do manage to get one wont it need coding to your car as well by someone with the correct tools/diagnostic etc.
Threads: 50
Thanks Given: 744
Unless you get a recon from somewhere like BBA Remanufacturing in Rochester then any second hand BSI will need coding or 'virginising'.
At least this is what I've been hearing over the last several months.
If someone has a BSI problem on an old van it's likely that the cost or availability of a BSI is the reason that the van is for sale.:S
hi my airbag light stays on until engine warms up plus rear door tries to look
