Threads: 8
Thanks Given: 296
29
There's no side scroll bar.
Working on the fixes for this, as I think I know the issue.
Threads: 40
Thanks Received: 125 in 102 posts
Thanks Given: 82
6
(29-03-2018, 08:34 AM)MarkT Wrote: I was also affected by this change. What I did was change the Board Style (User CP > Your Profile - Edit Options > Other Options) to 'Berlingo Responsive - 1.01'. That seemed to sort it out. The strange this is, that if I change it back to default, the problem doesn't re-appear.
Might be worth a try
Thanks Mark - worked great for me, I can see posts again!
Now an ex Berlingo owner, I have a C4
2010 (B9) Berlingo Multispace XTR HDi 112 - Kyanos Blue
Previously - 2002 (M49) Berlingo Multispace 2.0 HDi Diesel - Arctic Steel
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• MarkT
Threads: 40
Thanks Received: 387 in 344 posts
Thanks Given: 127
27
(31-03-2018, 08:10 PM)Mike Wrote: (29-03-2018, 08:34 AM)MarkT Wrote: I was also affected by this change. What I did was change the Board Style (User CP > Your Profile - Edit Options > Other Options) to 'Berlingo Responsive - 1.01'. That seemed to sort it out. The strange this is, that if I change it back to default, the problem doesn't re-appear.
I got to the " Other Options " bit then couldn't find the "Berlingo Responsive" bit, then when I went back to read the instructions again it back to was normal
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 12
Thanks Received: 44 in 29 posts
Thanks Given: 28
(01-04-2018, 06:29 AM)brodfather11 Wrote: (31-03-2018, 08:10 PM)Mike Wrote: (29-03-2018, 08:34 AM)MarkT Wrote: I was also affected by this change. What I did was change the Board Style (User CP > Your Profile - Edit Options > Other Options) to 'Berlingo Responsive - 1.01'. That seemed to sort it out. The strange this is, that if I change it back to default, the problem doesn't re-appear.
Just for info the 'Berlingo Responsive - 1.01' is in a drop down list at the end of Other Options, but if it all ok for you now brodfather, maybe it's just by going into the edit options that seems to reset the display settings.
Sent from my SM-T810 using Tapatalk
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Threads: 40
Thanks Given: 127
27
01-04-2018, 09:04 AM
(This post was last modified: 01-04-2018, 09:06 AM by brodfather11.)
[/quote]Just for info the 'Berlingo Responsive - 1.01' is in a drop down list at the end of Other Options, but if it all ok for you now brodfather, maybe it's just by going into the edit options that seems to reset the display settings.
[/quote]
Whatever it was its Ok now even though nothing was changed. As you say maybe just going to edit is enough to sort it.
The Anti-Voodoo dance on the desktop had probably nothing to do with it,
( OR DID IT ?????? )
Threads: 12
Thanks Given: 28
01-04-2018, 02:56 PM
(This post was last modified: 01-04-2018, 03:18 PM by MarkT.)
Quote:Just for info the 'Berlingo Responsive - 1.01' is in a drop down list at the end of Other Options, but if it all ok for you now brodfather, maybe it's just by going into the edit options that seems to reset the display settings.
Quote:Whatever it was its Ok now even though nothing was changed. As you say maybe just going to edit is enough to sort it.
Never underestimate the power of the anti-voodoo dance when it comes to computers.
The following 1 user says Thank You to MarkT for this post:1 user says Thank You to MarkT for this post
Should be fixed. Still got some updates to fix, will get them done asap thank you for the patience and help.
Thanks Given: 67
All back to normal here thanks.
