Thanks Given: 4
Hiya, another bloody fault now. At traffic lights, tick over erratic. I’ve taken air intake off and butterfly valve on engine appears to be jerking open and closed ever so slightly on tick over. Any suggestions good people?
Cheers in advance
Thanks Given: 67
MAF sensor probably, try disconnecting it.
Thanks Given: 316
15
You need to get the diag done really as it could be anything - is it a 1.6hdi?
Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
Simple things first see if you have a vacuum leak.
The following 1 user says Thank You to V6BOY for this post:1 user says Thank You to V6BOY for this post
• Lovebus
Thanks Given: 316
15
Sounds like you have knocked something recheck all your work
Threads: 6
Thanks Received: 8 in 6 posts
What's the tick over like?
Fast tick over as if the throttle is slightly open?
Low and lumpy tick over, sounds like a bag of nuts?
Or, is the engine revving up and down?
Might give someone on here a clue. I think you have already mentioned this only happens once the engine has warmed up?
2006 Citroen Berlingo Enterprise 600D
420k+ on the clocks and still chugging away
