Threads: 63
Thanks Given: 410
Have a trawl around the site, this has been discussed before....
Threads: 40
Thanks Received: 125 in 102 posts
Thanks Given: 82
6
Yep - don't assume that just because the light doesn't come on that it isn't working - it just doesn't need too. Does it start ok?
The light on mine only comes on in winter.
Now an ex Berlingo owner, I have a C4
2010 (B9) Berlingo Multispace XTR HDi 112 - Kyanos Blue
Previously - 2002 (M49) Berlingo Multispace 2.0 HDi Diesel - Arctic Steel
Thanks Given: 44
I've never seen a glowplug light come on yet. With a modern HDI diesel you just turn the key. If its starting ok theres no problem.
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Correct both.
The light only comes on during cold conditions.
Does mention this in the handbook.
Had mine since April and not come on yet.
Starts first time with no problems.:thumbsup:
Threads: 41
Thanks Received: 30 in 27 posts
Thanks Given: 16
Did anyone find the location of this relay? I'm just about to change mine (fault reported in Lexia) so would like to know where to look.
Threads: 17
Thanks Given: 153
(21-10-2011, 10:58 AM)knobblywobbly Wrote: Did anyone find the location of this relay? I'm just about to change mine (fault reported in Lexia) so would like to know where to look.
Is it to the left of the nearside headlight?
If not, under battery tray?
Or trace wiring from glowplugs themselves to find the relay...
Think it varies quite a lot from model to model anyway...
Happy hunting!
Thanks Received: 10 in 9 posts
HI, Thanks for all the info, I still havent found the relay. It does start on the third turn of the key, the battery is quite oldish from the way it looks, battery has 12.5 volts in it,Engine turns over quickly then slows down ,seems to lack amps ??. Is it just a matter of a new battery ?? £65.00 to find out.
Once its running its goes well, 51K miles etc.
