Hi folks
Thanks for the help in the other post about the gear oil (in the wrong place (sorry) - now below). Think I can find the plugs now!:
I would like to check my gear oil level and possibly change it too. I'm getting a small drip of oil on my drive and it appears to be coming from the near side of the engine (gearbox side). Is this common? I can't seem to tell what the oil is as it doesn't whiff like gear oil used to, but with modern oils perhaps it wouldn't. I suspect it is just engine oil but want to check the gearbox as a precaution. I understand the gear oil is not generally changed in services - is that right or is there a service interval that includes it?
Also are there any known common oil leak points?
Still interested to learn if leaks (engine/gearbox) are common and possible suspects. Also can BE4 gear oil be identified by smell?
thanks for reading....any help most appreciated.
'07 600x 1.6HDI 75 Berlingo (M59) short van
RPO: 11251
Engine: DV6B Gearbox: BE4-5L
RPO: 11251
tudy: MK2 1.6HDi 75 short van '600' M59
'07, 80k
DV6B Engine
BE4-5L manual gearbox
'07, 80k
DV6B Engine
