27-01-2022, 06:55 PM
(This post was last modified: 27-01-2022, 06:59 PM by middgm.)
Hi all
Just noticed that when I reverse the screen doesn't show obstacles on it. The settings are set to on so it should work as normal.
Does it mean the sensors are broken ?
Reverse lights are working OK but nothing appears on the screen
Any ideas please
Threads: 38
Thanks Received: 66 in 63 posts
Thanks Given: 122
7
Are the sensors clean? The roads are filthy at this time of year, and the manual recommends keeping the sensors clean (though my van's sensors are working even though they're covered in a layer of grime).
Work van: 2020 1.5 BlueHDi 100 Enterprise Berlingo
Spare van: 2001 1.9 600d Berlingo
The following 1 user says Thank You to notsofast for this post:1 user says Thank You to notsofast for this post
• middgm
Would it stop the screen on the dashboard showing the reverse animation starting?
Just cleaned them, nothing on the screen. By the way the screen is working perfectly in every other respect
Threads: 38
Thanks Given: 122
7
(27-01-2022, 07:17 PM)middgm Wrote: Would it stop the screen on the dashboard showing the reverse animation starting?
Not sure but I'd think unlikely. But if they are dirty, there's no harm in wiping them with a damp cloth and seeing if anything changes.
• middgm
Threads: 38
Thanks Given: 122
7
(27-01-2022, 07:20 PM)middgm Wrote: Just cleaned them, nothing on the screen. By the way the screen is working perfectly in every other respect
Has it just started doing it? Might be just a temporary blip. These screens can be a bit temperamental - mine occasionally reverts to showing everything in French.
Yes it has , strange really because the screen has been OK since I got it. Its as though the signal isn't telling the screen to show the function.
I'm assuming the action of putting it in reverse starts the process, if that's the case I wonder if there's a fuse gone.
Berlingo history
05 Petrol van 1.4 l - 255000 miles
Then
09 Petrol van 1.4l - 537000 miles
Then
10 Petrol van 1.6l - 415000 miles
Now
2019 Diesel van currently over 205000 miles
Threads: 38
Thanks Given: 122
7
(27-01-2022, 07:32 PM)middgm Wrote: Yes it has , strange really because the screen has been OK since I got it. Its as though the signal isn't telling the screen to show the function.
Yeah, mine starts once I put it into reverse - the screen changes and there's a beep.
Threads: 38
Thanks Given: 122
7
This web page -
https://asacannes.com/en/probleme-de-rad...-berlingo/ - lists some possible causes of the reversing warning not working. A process of elimination suggests it could be a fuse. It also suggests a test of the sensors involving bringing a coin close to each sensor and listening for a 'sizzle'.
• middgm
Threads: 75
Thanks Received: 1,281 in 1,134 posts
Thanks Given: 223
162
31-01-2022, 09:08 AM
(This post was last modified: 31-01-2022, 09:09 AM by Sol.)
Have you hit the switch on the dash to disable the rear park assist by accident? On my B9 it was down on the right next to the steering wheel but just out of sight. Not sure where it would be on the K9.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
