Thanks Given: 9
Hi all, I've got a strange Horn problem ! The horn works when the key is Not in the ignition, when I put it in, it doesn't work and also when I start up, it doesn't work??? But I've found that sometimes(once or twice) it has worked with it in the ignition and engine running.!!! Has anyone any idea what it can be, Please. Many thanks
Thanks Given: 188
23
Make sure everything is shut down and turned off all doors are shut and drivers window down. Disconnect the battery and leave for ten minutes then remove the steering wheel cowl to gain access to the back of the wheel. You then need a short screwdriver to go in the holes in the back of the wheel to flick the 3 spring clips to get the airbag off. Its a bit of a fiddle and do not use to much force. Be careful once the airbag is off and support it out of the way. You will then see the crap earth connection that just fits in a hole its like a U shaped spade connector. I just cut it off put a ring connector on it and drilled a small hole near the original and used a self tapper to secure it. Just a matter of putting it all back together again.
If you are unsure on getting the airbag off its in the Haynes manual.
Are we there yet?????
The following 1 user says Thank You to Tomcat3 for this post:1 user says Thank You to Tomcat3 for this post
• Reg
Thanks Given: 9
Thank you all for help, I will look at the earth wire.. Thanks
Thanks Given: 9
Hi, thanks to all of you, my horn problem is solved.. I made a better earth with wire, now it's working.. Thanks again for your replies..
The following 1 user says Thank You to Reg for this post:1 user says Thank You to Reg for this post
• brodfather11
