Threads: 42
Thanks Received: 81 in 54 posts
Thanks Given: 34
7
Took mine out on my 2008 Berlingo Multspace a few months back to get the part number of the display. There are no screws. The display surround is simply clipped in place. I used a set of plastic trim removal tools to get underneath and carefully lever off [you need at least two tools to lever up the clips] The whole surround comes off complete with the display which has a quick release connector for the display power/data. The display then [I think] then unscrews from the surround. When you refit it after plugging it back in you have to reset all the time/date etc. Another thing to note is that, when removing the surround sometimes the clip stays on the surround bit you are removing and sometimes stays on the dash part of the vehicle, before refitting make sure all the clips are on the surround part you have removed otherwise it doesn't like to clip back in place correctly.
Threads: 19
Thanks Received: 4 in 4 posts
Took it out without any problems but it's not well. 1 line of dead pixels right in the middle of the screen where you would select menu items. I will need to invest in new one.
Sent from my SM-G920F using Tapatalk
2012 (62) B9 Berlingo 1.6 Hdi (75hp)
