  • 1 Vote(s) - 3 Average
Driveshaft Nut Torque? Mk1 2001.
Hi all,
Seeing as I'm told they're the same from the bulkhead forward, does anyone happen to know what the driveshaft nut on my 2001 Pug Partner should be torqued up to?
I have a funny feeling I read somewhere, something crazy like 225lb/ft.
Cheers in advance Wink
Will
(01-12-2014, 09:47 PM)madwelshman Wrote:  Hi all,
Will
Mr Haynes, he say 320 Nm / 236 lbf ft
Only one setting in Berlingo manual.
Malcolm.
2001 1.9D Multispace.
Diagbox diagnostics in Northumberland.
I've been told 320nm for M24 nuts and 245nm for M20.5 nuts.
Cheers guys, much appreciated.
I'm guessing the bearings are the same, just a difference in the driveshaft nut size.
The bearing that was supplied to me going by my reg number, had the smaller nut, but my shafts have the bigger nuts.
All went together fine and there was no play in it, but now, after about 40 miles of use, I have a creaking noise when I rock the top of the wheel with the car on the ground and also sometimes when driving you can hear it.
Think I'm gonna have to pull the hub off again and check the bearing, even though it's a new one Sad
Creaking noise cured. Happy again now Big Grin
(03-12-2014, 10:05 PM)madwelshman Wrote:  Creaking noise cured. Happy again now Big Grin
You have not said what the creaking was please tell us smile
NO! CAN'T! WON'T! lol
Oh, ok.
The wheel nuts weren't tight enough. When I put the wheel on last, I nipped them with my impact gun. I then tightened them as I would with any steel wheel to a decent tightness. Admittedly, I didn't and don't tend to torque them on any of my cars, but I've never had a problem with wheel nuts/bolts done up tight enough that I can still get them off at the side of the road with a standard T bar but not needing a power bar. This has never been a problem in the past, so I am a little surprised (and embarrassed!)
Not to worry we've all done some thing like that except ( RON ) of course ??
(05-12-2014, 09:56 PM)Jed Clampit Wrote:  Not to worry we've all done some thing like that except ( RON ) of course ??
No,my nuts are always tight.Couldn't bear to lose one. Wink Wink
Clutch issue?
Last Post: Paul04
Yesterday 08:07 PM
Adding heated seats to a k9
Last Post: ComboLifer
Yesterday 07:24 PM
Yesterday 07:22 PM
Yesterday 07:16 PM
Rip off van servicing
Yesterday 07:14 PM
Rumbling from front suspension
Yesterday 07:12 PM
Last Post: Stu1
Yesterday 02:40 PM
help required
Yesterday 08:22 AM
Hello all
Yesterday 08:18 AM
Yesterday 08:18 AM
