Hi all I am after a jack and wheelbrace for a 2005 2.0HDI. I know there are others which might fit so if it does let me know. I am in Stockport and can collect ??
27-11-2016, 10:15 AM (This post was last modified: 28-11-2016, 10:37 AM by ffrenchie.)
I keep an extending wheel brace in the cargo net on the left side of the boot. Any one ton scissor jack should do the job, scrapyards usually have them but you need something flat to unscrew the wheel release hook. Peugeot 206 uses a similar brace tool and there are plenty of those in scrapyards.
Where did you get the wheel brace from and is it any good? Wouldn't mind one myself. and only wanted a Citroen one to fit in the side compartment bit in the boot out of the way
27-11-2016, 06:13 PM (This post was last modified: 27-11-2016, 06:43 PM by Tomcat3.)
This the type I use http://www.ebay.co.uk/itm/Extendable-Whe...SwHnFV69eM
and keep it in the tray under the passenger seat.
Much easier to extend and undo stubborn bolts just remember do the bolts up in shortened mode.
Are we there yet?????
The following 1 user says Thank You to Tomcat3 for this post:1 user says Thank You to Tomcat3 for this post • Silverberlingo
(27-11-2016, 06:13 PM)Tomcat3 Wrote: This the type I use http://www.ebay.co.uk/itm/Extendable-Whe...SwHnFV69eM
Much easier to extend a undo stubborn bolts just remember do the bolts up in shortened mode.
27-11-2016, 06:42 PM (This post was last modified: 27-11-2016, 06:43 PM by Jed Clampit.)
(27-11-2016, 10:15 AM)ffrenchie Wrote: I keep an extending wheel brace in the cargo net on the left side of the boot. Any one ton scissor jack should do the job, scrapyards usually have them but you need something flat to unscrew the wheel release hook. Peugeot 206 uses a similar brace tool and there are plenty of those in scrapyards.
That's a funny place to keep a brace how long do you hang them before cooking don't they smell .
It's too orangey for crow's It's just for me and my dog
28-11-2016, 10:32 AM (This post was last modified: 28-11-2016, 10:34 AM by ffrenchie.)
(27-11-2016, 05:54 PM)Silverberlingo Wrote: Where did you get the wheel brace from and is it any good? Wouldn't mind one myself. and only wanted a Citroen one to fit in the side compartment bit in the boot out of the way
Most car spares have them but online Cromwell sell one for under £5 with a 17mm and 19mm socket. It works well even gets the wheel nuts off when the tyre fitter has gone crazy with the nut runner.
28-11-2016, 10:38 AM (This post was last modified: 28-11-2016, 10:40 AM by ffrenchie.)
