Threads: 121
Thanks Given: 248
34
Does anyone know if it's possible to activate the boot unlock button from a 3 button remote on a car that originally came with a 2 button remote?
I've just had a new 3 button remote from a locksmith, the lock / unlock works fine, just wondered if it was a Lexia / Diagbox option to make the 3rd button work.
Thanks Received: 14 in 13 posts
Thanks Given: 4
We've got a 3 button fob but its for a van and it just unlocks the back doors and not the front two, it does have a picture of van back doors on the middle button though. What do you mean by boot, is this a Berlingo or something else.
As for Diagbox I've programmed a couple of keys and all it wanted was the key putting into the ignition turning off then back on and it was programmed, it never asked what type of key it was or how many buttons. The only thing it did ask for was how many keys were being programmed in, you have to reprogram any original ones you have already got or these won't work afterwards.
You do have to set up the central locking manually after you've programmed the key though, you turn on the ignition and then hold one of the buttons for a few seconds to code it in, maybe try holding the boot button down.
Thanks Given: 4
All I know is when you program the buttons you only hold one of them down and then they all work, so I just turned the key on, held the lock button down for a few seconds and then all 3 buttons worked on the fob. I didn't see any settings whatsoever for the buttons when I was programming the immobiliser side of things in Diagbox.
Maybe the middle button only works if there is a separate section on the vehicle for the rear part or if it has an electric tail gate release so it pops up when pressed.
