If you have the usual 1.6hdi air filter rattle because the 2 rubber locating grommets have gone awol or in my case the ham fisted muppets had broken one of the lugs off the bracket there is an uprated metal bracket.
Its a straight swap for the plastic bracket just a bit of hassle to do as you have to remove some of the egr pipework as the left 10mm nut holds on part of the pipework, The right hand is an 8mm bolt. While I had the egr loosened off I took the opportunity to blank off the egr with a plate.
The bracket is part number 1436S4 and cost me 11 quid complete with 2 grommets and has stopped the rattling now.
:thumbsup:
Ps the 8mm bolt on the right will need shortening by 20-25mm or use a replacement as the new bracket doesnt use a spacer built into the old plastic bracket.
:thumbsup:
Are we there yet?????
